Accessing the Report from a Host-Mounted Volume
If the volume mounted at /logMount in the UIM pod is also mounted on an administration host, access the report from the corresponding host mount path. For example, if /logMount maps to /uim/shared/logMount on the administration host, the report is available at: /uim/shared/logMount/UIM_ENTITY_AUDIT.xlsx
The actual host path depends on the Kubernetes PersistentVolume and storage configuration. The pod path does not indicate that the volume is mounted on the administration host.
