Copying the Report from a UIM Pod
If /logMount is not mounted on the administration host, copy the report from the UIM pod with kubectl cp as follows:
NAMESPACE=<uim-namespace>
POD=<uim-pod-name>
CONTAINER=<uim-container-name>
kubectl cp \
"${NAMESPACE}/${POD}:/logMount/UIM_ENTITY_AUDIT.xlsx" \
./UIM_ENTITY_AUDIT.xlsx \
-c "${CONTAINER}"For example:
kubectl cp \
uimdev1/uimdev1-topology810-ms1:/logMount/UIM_ENTITY_AUDIT.xlsx \
-c <uim-container-name>If the ruleset generates the report in ${uim.home}, replace the pod source path with the complete path reported in the UIM server log.
To confirm that the report exists before you copy it, run:
kubectl exec -n "${NAMESPACE}" "${POD}" -c "${CONTAINER}" -- \
ls -l /logMount/UIM_ENTITY_AUDIT.xlsx
