5 Deploying OpenSearch and OpenSearch Dashboard
This chapter describes how to deploy the OpenSearch service and OpenSearch dashboard.
Configuring OpenSearch and OpenSearch Dashboard Images
The Common CNTK has a sample that provides deployment instructions for OpenSearch on Kubernetes cluster using Helm charts. For more information, see https://opensearch.org/docs/latest/install-and-configure/install-opensearch/helm/
You can install any OpenSearch available in the market. Oracle recommends you to use OCI OpenSearch or OpenSearch with the configuration parameters provided under samples directory in common-cntk.
Installing OpenSearch Helm Charts
To install OpenSearch Helm charts, run the following commands:
helm repo add opensearch https://opensearch-project.github.io/helm-charts/
helm repo update
helm search repo opensearch //you should see 2 charts opensearch/opensearch & opensearch/opensearch-dashboard
Creating an OpenSearch and OpenSearch Dashboard Instance without SSL and Oauth Enablement
This section provides information on creating an OpenSearch and OpenSearch Dashboard instance without having SSL and Oauth enablement.
Setting up Environment Variables
OpenSearch and OpenSearch Dashboard rely on access to certain environment variables to run seamlessly across different environments. The OpenSearch charts are available at $COMMON_CNTK/samples/charts/opensearch.
The environment variables are configured in $COMMON_CNTK/samples/charts/opensearch/scripts/env.sh.
Configure OPENSEARCH_CHART_VERSION, OPENSEARCH_DASHBOARD_CHART_VERSION, and OS_NAMESPACE in env.sh script.
To set up the environmental variables:
  1. Set the OpenSearch namespace as follows:
    export OS_NAMESPACE=sr
  2. Set the OpenSearch chart version as follows:
    export OPENSEARCH_CHART_VERSION=<chart version>
  3. Set the OpenSearch dashboard chart version as follows:
    export OPENSEARCH_DASHBOARD_CHART_VERSION=<OpenSearch Dashboard chart version>
For the corresponding OpenSearch chart versions, see Unified Inventory and Topology Microservices.
For OpenSearch configuration overrides, see "Assembling the Specifications". To override the default values, edit the $SPEC_PATH/$OS_NAMESPACE/opensearch/os_board_values.yaml and $SPEC_PATH/$OS_NAMESPACE/opensearch/os_engine_values.yaml files.
Install OpenSearch as follows:
$COMMON_CNTK/samples/charts/opensearch/scripts/create-opensearch.sh
To configure Persistence and Storage for OpenSearch, provide storage class name under storageClass as follows:
persistence:
  storageClass: <storageclass>
If you use a private or alternative Docker registry, provide the registry URL in the following command. For example: "myregistry.example.com":
global:
  dockerRegistry: ""
Installing OpenSearch Dashboard
Install the OpenSearch dashboard using the following command:
$COMMON_CNTK/samples/charts/opensearch/scripts/create-opensearch-dashboard.sh
Accessing the OpenSearch Dashboard Service
Access the OpenSearch dashboard using the node port of the OpenSearch dashboard service in the namespace.
export NODE_PORT=$(kubectl get --namespace $OPENSEARCH_NS -o jsonpath="{.spec.ports[0].nodePort}" services os-board-opensearch-dashboards)
export NODE_IP=$(kubectl get nodes --namespace $OPENSEARCH_NS-o jsonpath="{.items[0].status.addresses[0].address}")
echo http://$NODE_IP:$NODE_PORT
Installing FluentD
Update the $COMMON_CNTK/samples/charts/fluentd/template/fluentd-config-map.yaml file with OpenSearch details such as type, host, port, scheme, user, password, and ssl_verify as follows:
#Export the kubernetes namespace to be used for OpenSearch installation
helm install fluentd-logging $COMMON_CNTK/samples/charts/fluentd --values $COMMON_CNTK/samples/charts/fluentd/values.yaml
Creating an OpenSearch and OpenSearch Dashboard Instance with SSL and Oauth Enablement
This section provides information on creating an OpenSearch and OpenSearch Dashboard Instance with SSL and Oauth enablement.
To set up environmental variables, see Setting up Environment Variables.
Configuring config.yml
While configuring $COMMON_CNTK/samples/charts/opensearch/config.yml for OpenSearch with an Identity Provider (IdP), set up authentication parameters to enable seamless and secure integration.
To configure config.yaml:
  1. Define the openid_connect_idp settings to include the discovery URL, client ID, and client secret of the IdP, which are essential for OpenID Connect (OIDC) authentication.
  2. Specify the authorization and token endpoints provided by the IdP to handle user logins and configure role mapping to assign user roles based on the IdP attributes.
This setup allows OpenSearch to authenticate users through the IdP, easing access management while enhancing the security and compliance using:
  • openid_connect_url: The OpenID configuration URL of IdP.
  • client_id and client_secret: To securely authenticate OpenSearch with the Identity Provider (IdP) for OpenID Connect.
Creating Secrets in OpenSearch
To create secrets in OpenSearch:
  1. Create a Kubernetes secret for the IdP trust certificate as follows:
    kubectl create secret generic <opensearch-namespace>-opensearch-idp-cert  --from-file idp-chain-cert.pem=<IDP chain cert path> -n <opensearch-namespace>
  2. Create a Kubernetes secret for OpenSearch IdP configuration after providing the required information in config.yml as follows:
     kubectl create secret generic <opensearch-namespace>-opensearch-idp-config-secret --from-file config.yml=<path/config.yml> -n <opensearch-namespace>
  3. Configure rolesMappingSecret for OpenSearch roles mapping as follows:
     kubectl create secret generic <opensearch-namespace>-opensearch-rolesmapping-secret --from-file roles_mapping.yml=<path/role_mapping.yml> -n <opensearch-namespace>
  4. Configure internalUsersSecret for OpenSearch internal users as follows:
    kubectl create secret generic <opensearch-namespace>-opensearch-internalusers-secret --from-file internal_users.yml=<path/internal_users.yml> -n <opensearch-namespace>
    The default username and password are used.
Implement Custom Certificates in OpenSearch
To implement custom certificates in OpenSearch:
  1. Create the common certificates and common keys.
  2. Create a secret from the common certificate and common key as follows:
     kubectl create secret generic <opensearch-namespace>-opensearch-keystore-cert --from-file=commoncert.pem=<path/commoncert.pem> --from-file=commonkey.pem=<path/commonkey.pem> -n sr
  3. Provide the secretName under secretMounts in os_engines_values.yml as follows:
    - name: commoncertandkey
      secretName: <opensearch-namespace>-opensearch-keystore-cert
      path: /usr/share/opensearch/config/certs
  4. Provide the Distinguished Names (DNs) for authorized admin users in plugins.security.authcz.admin_dn and for trusted nodes in plugins.security.nodes_dn to control the access and secure node communication in OpenSearch.
  5. Configure disabling of the installation of demo configuration settings that include demo users, roles, and certificates as follows:
    env:
      value: true
  6. Update os_engine_values.yaml to enable Security Plugin for OpenSearch. Comment the following section or set the value to false:
    extraEnvs:
    - name: DISABLE_SECURITY_PLUGIN
      value: "false"
Create an OpenSearch Instance
To create an OpenSearch instance:
  1. To create an opensearch instance:
  2. Run the runsecurity-admin.sh script to apply the changes that are made while implementing the custom certificates as follows:
    $COMMON_CNTK/samples/charts/opensearch/scripts/runsecurity-admin.sh
Configuring opensearch_dashboards.yml for OpenSearch Dashboards Settings
The opensearch_dashboards.yml configuration file is essential for setting up and customizing the behavior of OpenSearch Dashboards. This file contains various settings that control how the dashboards interact with OpenSearch, including authentication, security, and connection parameters as follows:
  • opensearch.password: The Basic Authentication password for accessing OpenSearch.
  • opensearch_security.openid.base_redirect_url: The redirect URL for OpenSearch authentication.
  • opensearch_security.openid.connect_url: The OpenID configuration URL of IdP.
  • opensearch_security.openid.client_id: The client ID for OpenSearch authentication with the IdP.
  • opensearch_security.openid.client_secret: The client secret to secure communication with the IdP.
  • opensearch_security.openid.scope: The authentication scope.
Creating Secrets in OpenSearch Dashboard
To create secrets for OpenSearch Dashboard:
  1. Create a Kubernetes Secret with the IdP trust Certificate and mount the secret in os_board_values.yml under secretMounts as follows:
    kubectl create secret generic <opensearch-namespace>-opensearch-idp-cert --from-file idp-chain-cert.pem=<Path/IDP chain cert path> -n <opensearch-namespace>
    You may skip this step if you have created a Kubernetes secret for OpenSearch earlier.
  2. Create a Kubernetes secret containing the OpenSearch Dashboards configuration and the corresponding location within the container:
    kubectl create secret generic <opensearch-namespace>-opensearch-dashboard-config --from-file=opensearch_dashboards.yml=<path/opensearch_dashboards.yml> -n <opensearch-namespace>
Setting up Ingress Controller for OpenSearch Dashboard
Using HAProxy as an Ingress Controller for OpenSearch Dashboards provides a highly configurable and stable solution for managing external access to your OpenSearch environment. By deploying HAProxy as the ingress, you can direct traffic to OpenSearch Dashboards using custom routing rules, including domain-based and path-based routing, allowing a better traffic control. You can use any Generic Ingress Controller that is available in the market. The following samples are for HAProxy.
The OpenSearch Dashboards integrate seamlessly with HAProxy ingress in Kubernetes environments to provide secure and scalable access. By leveraging the HAProxy ingress controller, administrators can share the Dashboards service externally, allowing users to interact with the OpenSearch data through a web-based interface.
To setup HAProxy for dashboard, configure below values in os_board_values.yml:
  • ingressClassName: Provides the ingress class name value under the ingress.ingressClassName field.
  • secretName: Defines the TLS secret that contains the SSL certificate for HTTPS.
  • tls.host: Specifies the domain for accessing OpenSearch Dashboards over HTTPS.
  • hosts.host: Specifies the domain for accessing OpenSearch Dashboards over HTTPS.
Run the following to create the secret:
kubectl create secret tls <project>-<instance>-opensearch-ingress-tls-cert-secret --cert=<path/commoncert.pem> --key=<path/commonkey.pem> -n <os-namespace>
Registering OpenSearch or OpenSearch Dashboard in Identity Provider
You must create Oauth 2.0 client in your IDP. You can use the same client created for ATA service. For more information, see "Registering ATA in Identity Provider".
In addition to the steps you perform while registering ATA in IdP, add the redirect URI: https://<opensearch-instance>.<opensearch-namespace>.opensearch.uim.org:<LB-PORT>/auth/openid/login
Add the following Post Logout Redirect URI:
Create OpenSearch Dashboard Instance
To create a OpenSearch dashboard instance, run the following command:
Access the OpenSearch dashboard URL that should redirect to the IdP login page. After you successfully log in, the OpenSearch dashboard appears.
Dashboard URI:  https://<instance>.<project>.opensearch.<hostSuffix>:<ingressController-port>/app/home#/
Example: https://quick.sr.opensearch.uim.org:30543/app/home#/
Make sure you add the entry in the hosts file: <k8s cluster ip or external loadbalancer ip> <instance>.<project>.opensearch.<hostSuffix>
Installing and Upgrading the OpenSearch Schema
Starting with release 2.1.0.0.0, the OpenSearch schema installer is included in the ATA DB installer. Use the ATA DB installer to create and upgrade the OpenSearch schema, indexes, aliases, mappings, and metadata used by Service Impact Analysis and Network Plan and Build.
You no longer need to run the indexConfig.sh commands manually to create indexes or update metadata.
Configuring the OpenSearch Schema Installer
The OpenSearch schema installer uses the current application specifications in $SPEC_PATH. By default, it derives the OpenSearch and Smart Search URLs, authentication settings, and TLS settings from the application specifications.
You do not need to add OpenSearch settings to database.yaml unless your deployment requires values that differ from the current application specification settings.
To override the derived settings, update the ata-dbinstaller.search section in $SPEC_PATH/$PROJECT/$INSTANCE/database.yaml. For example:
ata-dbinstaller:
  search:
    opensearch:
      url: "<OpenSearch_URL>"
      auth:
        enabled: true
      indexConfig:
        categories:
          smartsearch:
            shards: 3
            replicas: 1
          framework:
            shards: 1
            replicas: 1
        indexes:
          smartsearch-event:
            shards: 5
            replicas: 0
    smartsearch:
      url: "<SmartSearch_URL>"
    tls:
      enabled: true
The opensearch.url and smartsearch.url settings are optional. Specify these settings only when the installer must connect to endpoints that differ from those derived from the current application specifications.
The indexConfig section is optional. Use it only when the default number of shards or replicas is not appropriate for your deployment. You can configure a value for an index category or for an individual index. A setting for an individual index takes precedence over the setting for its category.
The following constraints apply:
  • shards must be greater than or equal to 1.
  • replicas must be greater than or equal to 0.
When OpenSearch authentication is enabled, ensure that the instance has the openSearchCredentials credential. The ATA DB installer also requires the database credential.
Creating the OpenSearch Schema
To create the OpenSearch schema:
  1. Review the current application specifications in $SPEC_PATH/$PROJECT/$INSTANCE. If the derived OpenSearch, SmartSearch, authentication, and TLS settings are appropriate for your deployment, do not add the ata-dbinstaller.search section to database.yaml.
  2. (Optional) Update the ata-dbinstaller.search section in database.yaml with the OpenSearch settings for your deployment.
  3. Ensure that the required instance credentials are available. When OpenSearch authentication is enabled, the database and openSearchCredentials credentials are required.
  4. Run the ATA DB installer:
    $COMMON_CNTK/scripts/install-database.sh -p $PROJECT -i $INSTANCE -s $SPEC_PATH -a ata -c 10
  5. Validate the OpenSearch schema by using OpenSearch Dashboard Developer Tools. Run the following requests:
    GET _cat/aliases/applicationinfo?v
    GET _cat/indices/applicationinfo?v
    GET applicationinfo/_mapping
    GET applicationinfo/_search?q=version.type:OPENSEARCH&size=1
  6. Confirm that the applicationinfo alias, backing index, mapping, and an OPENSEARCH version record are present.
To upgrade the OpenSearch schema:
  • Review the current application specifications in $SPEC_PATH/$PROJECT/$INSTANCE. Use the settings derived from the current specifications unless your deployment requires an ata-dbinstaller.search override in database.yaml.
  • Ensure that the required instance credentials are available. When OpenSearch authentication is enabled, the database and openSearchCredentials credentials are required.
  • If you are upgrading from an earlier release, verify that the applicationinfo alias exists. If the alias does not exist, prepare the earlier releases for upgrade before continuing.
  • Run the ATA DB installer:
    $COMMON_CNTK/scripts/install-database.sh -p $PROJECT -i $INSTANCE -s $SPEC_PATH -a ata -c 41
    The upgrade preserves existing OpenSearch data. Do not delete OpenSearch indexes as part of the upgrade procedure.
  • Validate the upgraded schema by using OpenSearch Dashboard Developer Tools:
    GET applicationinfo/_search?q=version.type:OPENSEARCH&size=5
  • Confirm that the applicationinfo alias, backing index, mapping, and active OPENSEARCH record are present.
Preparing Earlier Releases for Upgrade
Use this procedure only when you are upgrading from an earlier release whose OpenSearch cluster does not contain the applicationinfo alias. Complete this procedure before you upgrade the OpenSearch schema. 1.
To prepare earlier releases for upgrade:
  1. In OpenSearch Dashboard, open Developer Tools.
  2. Check whether the alias exists:
  3. If the alias is missing, create the applicationinfo-1 index and assign the applicationinfo alias:
    PUT applicationinfo-1
      "aliases": {
        "applicationinfo": {}
      "settings": {
        "index": {
          "number_of_shards": 1,
          "number_of_replicas": 1
      "mappings": {
        "properties": {
          "buildDate": {
            "type": "date"
          "createDate": {
            "type": "date"
          "createdUser": {
            "type": "keyword"
          "endDate": {
            "type": "date"
          "lastModifiedDate": {
            "type": "date"
          "lastModifiedUser": {
            "type": "keyword"
          "name": {
            "type": "keyword"
          "startDate": {
            "type": "date"
          "status": {
            "type": "keyword"
          "type": {
            "type": "keyword"
          "version": {
            "type": "keyword"
  4. Add the required OpenSearch schema version record:
    PUT applicationinfo/_doc/opensearch-schema-current
      "buildDate": "2026-06-15T08:59:22.576487425Z",
      "createDate": "2026-06-15T08:59:22.576487425Z",
      "createdUser": "admin",
      "lastModifiedDate": "2026-06-15T08:59:22.576487425Z",
      "lastModifiedUser": "admin",
      "name": "OpenSearch Schema",
      "startDate": "2026-06-15T08:59:22.576487425Z",
      "status": "ACTIVE",
      "type": "OPENSEARCH",
      "version": "1.3.0.0.0"
    Update the example values for your deployment. Set version to the exact version of the release from which you are upgrading.
  5. Upgrade the OpenSearch schema.
Troubleshooting the OpenSearch Schema Installer
If the installer fails, check the following items:
  • Confirm that database.yaml is available at $SPEC_PATH/$PROJECT/$INSTANCE/database.yaml.
  • If you added the ata-dbinstaller.search section, confirm that it overrides only the settings required for your deployment.
  • Confirm that the database credential is available. If OpenSearch authentication is enabled, confirm that the openSearchCredentials credential is also available.
  • If you use derived settings, confirm the current OpenSearch, SmartSearch, authentication, and TLS settings in the application specifications in $SPEC_PATH/$PROJECT/$INSTANCE.
  • Before upgrading from an earlier release, confirm that the applicationinfo alias and the OPENSEARCH version record are present.
To check an ATA DB installer failure:
  1. View the installer job log:
    kubectl logs -n $PROJECT $PROJECT-$INSTANCE-ata-dbinstaller
  2. Check the installer pod status:
    kubectl get pods -n $PROJECT
  3. If the installer pod is in the ContainerCreating, Pending, Error, CrashLoopBackOff, or CreateContainerConfigError state, describe the pod to view the reported error:
    kubectl describe pod $PROJECT-$INSTANCE-ata-dbinstaller -n $PROJECT
  4. If the ATA DB installer fails, remove its Helm release before rerunning the installer:
    helm uninstall $PROJECT-$INSTANCE-ata-dbinstaller -n $PROJECT
    This command removes the failed installer release. It does not delete OpenSearch schema data.
Upgrading the OpenSearch and OpenSearch Dashboard Service
This section provides information about upgrading the OpenSearch and OpenSearch dashboard services.
Upgrade OpenSearch Service
Upgrading OpenSearch is required when there are updates in the OpenSearch values yaml file.
To upgrade the OpenSearch instance:
$COMMON_CNTK/samples/charts/opensearch/scripts/upgrade-opensearch.sh
Upgrade OpenSearch Dashboard Service
Upgrading OpenSearch dashboard is required when there are updates in the OpenSearch dashboards values yaml file.
To upgrade OpenSearch dashboard service:
$COMMON_CNTK/samples/charts/opensearch/scripts/upgrade-opensearch-dashboard.sh
After running the script, verify the OpenSearch dashboard service by accessing it on a browser.
Deleting the OpenSearch and OpenSearch Dashboard Service
This section provides information on deleting the OpenSearch and OpenSearch dashboard services.
Deleting OpenSearch Service
To delete the OpenSearch instance:
$COMMON_CNTK/samples/charts/opensearch/scripts/delete-opensearch.sh
Deleting OpenSearch Dashboard Service
To delete the OpenSearch dashboard instance:
$COMMON_CNTK/samples/charts/opensearch/scripts/delete-opensearch-dashboard.sh
helm uninstall fluentd-logging --namespace=$OPENSEARCH_NS
Alternate Configuration Options for OpenSearch and OpenSearch Dashboard
This section provides alternate configuration options for OpenSearch and OpenSearch dashboard.
Changing the Default OpenSearch Basic Auth Password
To enhance security, update the default admin password in internal_users.yml by generating a hashed password using the OpenSearch hash script.
To change the default OpenSearch basic auth password:
  1. Navigate to the OpenSearch Security plugin directory in opensearch pod as follows:
    cd /usr/share/opensearch/plugins/opensearch-security/tools
  2. Run the following:
    ./hash.sh "<your-password>"
  3. Copy the hashed password and update internal_users.yml.
  4. Set the same password in opensearch_dashboards.yml.
  5. Replace the existing password hash with the new hashed value to secure the admin account.
  6. To ensure compatibility, add the same password (in plain text) under opensearch.password in opensearch_dashboards.yml.
    This configuration allows OpenSearch Dashboards to authenticate with the updated credentials, aligning password settings across both files.
Creating Ingest Pipeline for OpenSearch
Login to OpenSearch Dashboard and navigate to DevTools on the top-right corner of the Home page and run the following to add the lang_pipeline in OpenSearch:
PUT _ingest/pipeline/lang_pipeline
  "description": "Pipeline to ensure documents have a lang field",
  "processors": [
      "script": {
        "lang": "painless",
        "source": """
          if (ctx.lang == null) {
            throw new IllegalArgumentException('Document does not have the *lang* field');
Debugging and Troubleshooting
OpenSearch pods restarting with error, related to max virtual memory areas
When you get the error: vm.max_map_count [65530] is too low, increase it to at least [262144]. In OpenSearch pods, you need to set vm.max_map_count to 262144 on each worker node where the OpenSearch pod is getting scheduled. Run the following commands on the nodes:
sudo sysctl -w vm.max_map_count=262144
# Alternatively you can run the following to save changes permanently
echo "vm.max_map_count=262144" >> /etc/sysctl.conf
sysctl -p
After logging in to the OAuth-enabled OpenSearch dashboard, seeing user ID instead of username
If you get a user ID instead of a username in the user-info section, you can configure a custom property mapper to map the username to the sub claim of the access token and add it to your scope configured with the OAuth client.
In the case of Keycloak, you can create a user property mapper.
