2 About the Trouble to Resolve Reference Solution Archive Package
This chapter describes the contents of the Trouble to Resolve Reference Solution archive, which includes the reference solution package's details, the fault management use cases. It also outlines the event types, notifications, and device protocols for which the reference solution is tested.
The reference solution download archive includes the following components:
- Reference solution documentation
- Smoke Test artifacts
- Design time cartridges
- Runtime seed data
- Reference solution (DWDM, OTN, SNMP) artifacts
- Runtime seed data
- Extensions
Table 2-1 Reference Solution Package details
| Package | Format | Location | Sub Directories | Reference Solution Component | Details |
uniops-t2r-artifacts_.<tag>.<build_ number>.tar.gz |
Compressed |
uniops-t2r-artifacts\uim\cartridges |
common smoketest solution |
UIM |
Accelerates the process of defining a new Service domain by creating a domain package containing a single CFS-RFS-Resource structure that you can re-factor, expand, and link to, as needed. |
Compressed |
uniops-t2r-artifacts\uim\seeddata |
UIM |
Streamlines the expansion of a Technology domain definition by creating a default RFS-Resource structure. |
Compressed |
uniops-t2r-artifacts\ua\packages |
Unified Assurance |
Accelerates the process of expanding a Technology domain definition by creating a default Resource structure. |
