Connecting with Autodesk
To set up a connection with Autodesk, complete all the steps in sequence using the Add New Connection wizard.
Adding an Autodesk Connection
As an administrator, you can set up a connection to fetch image and related data from Autodesk Construction Cloud and Autodesk BIM 360.
Each administrator user can have only one connection with Autodesk. Construction and Engineering Intelligence supports having more than one connection to Autodesk, but each connection must made by a different Construction and Engineering Intelligence administrator user.To add a connection to Autodesk:
- From the
Navigation Menu, select Administration, then Data Management. - On the Data Source page, from the Add new connection drop-down list, select Autodesk and click Continue.
- On the Connection Details page, sign in with your Autodesk credentials:
Configuring Autodesk Settings
As an administrator, select Autodesk projects to fetch media and its associated data.
Creating an Initial Ingestion Schedule
To complete the connection setup with Autodesk, you will need to create an initial ingestion schedule to fetch project data at predetermined frequency into Construction and Engineering Intelligence.
The ingestion schedule created during initial connection setup cannot be deleted.Prerequisites
You have completed the following steps successfully:
Procedure
To set up the initial ingestion schedule for Autodesk project data:
- On the Ingestion Schedule page, click Done to:
- complete the Autodesk configuration setup in Construction and Engineering Intelligence
- set an automatic data ingestion schedule daily at 12:00 AM UTC
- Select any of the following actions:
- View the daily ingestion schedule automatically created for Autodesk on the Ingestion Schedule page.
- View the new Autodesk connection created on the Data Management page.
