Accessing Construction and Engineering Intelligence
When your organization is provisioned with Construction and Engineering Intelligence, you will receive the Construction and Engineering Intelligence Application URL in a Welcome email.
To sign in for the first time as a user of Construction and Engineering Intelligence:
  1. In your Welcome email, click the application URL
    For a list of supported browser versions, see Client System Requirements.
  2. In the Username field, enter the user name assigned to you.
  3. In the Password field, enter your password. After your initial sign in, you can proceed to Resetting Your Password.
  4. Click Sign In.
  5. Use the Navigator pane to explore the menu options available to you. For more details, see Navigation Overview.
