Navigation Overview
The Home page of Construction and Engineering Intelligence displays the following menu and options.
Menu / Option | Description |
Select to expand or collapse the Navigator pane. |
The Help menu displays the following options:
1 |
Displays the initials of the signed-in user. Select this option to sign out of the application. |
2 |
Navigator The Navigator displays the modules you can access based on your role and the modules your organization has purchased.
3 | The selected module page is displayed. You can select the tiles displayed on the page to navigate within the selected module. |
Navigating within the Application
You can navigate within the application using either the Navigator or the tiles on the page.
Using the Navigator:
- Click the
Navigation Menu to display the Navigator pane.
- In the Navigator pane, select a module.
Examples:
- To access the Administration module: From the Navigation Menu, select Administration.
- To access the Analytics module: From the Navigation Menu, select Analytics. A new tab opens with Oracle Analytics Cloud.
- To access the Benchmarks dashboard in the Safety module: From the Navigation Menu pane, select Safety, then select Benchmarks.
- To access the Monitoring dashboard in the Safety module: From the Navigation Menu select Safety, then select Monitoring.
Using tiles
From the Overview page or from any of the module pages, select the tiles displayed on the pane.
Examples:
- To select the Administration module: From the Overview page, select the Administration tile.
- To select the Analytics module: From the Overview page, select the Analytics tile. A new tab opens with Oracle Analytics Cloud .
- To access the Benchmarks dashboard in the Safety module: From the Overview page, select the Safety tile, then select the Benchmarks tile.
- To access the Monitoring dashboard in the Safety module: From the Overview page, select the Safety tile, then select Monitoring tile.
