Keyboard Shortcuts
General Interactive Keyboard Shortcuts
Action Keys
Move to the next tab stop Tab
Move to the previous tab stop Shift+Tab
Toggle between row selection and cell selection F8
Open the column header menu, when focus is on the column header Enter or Space
Increase column width, when focus is on the column header
Windows: Ctrl+Right arrow
Mac: Ctrl+Cmd+Right arrow
Decrease column width, when focus is on the column header
Windows: Ctrl+Left arrow
Mac: Ctrl+Cmd+Left arrow
Move column to next column position, when focus is on the column header Shift+Right arrow
Move column to the previous column position, when focus is on the column header Shift+Left arrow
Sort ascending on the current column, when focus is on the column header
Windows: Alt+Up arrow
Mac: Option+ Up arrow
Sort ascending on the current column in addition to the existing search columns, when focus is on the column header
Windows: Shift+Alt+Up arrow
Mac: Shift+Option+ Up arrow
Sort descending on the current column, when focus is on the column header
Windows: Alt+Down arrow
Mac: Option+ Down arrow
Sort descending on the current column in addition to the existing search columns, when focus is on the column header Mac: Shift+Option+Down arrow
Move to next tab stop in column header menu, when column header menu is open Tab
Move to previous tab stop in the column header menu, when column header menu is open Shift+Tab
Close the column header menu, when the column header menu is open Escape
Show help (if defined) for an item, when a single row is viewed and focus is on the column
Windows: Alt+F1
Mac: Option+F1
Date Picker
Action Keys
Open the popup, when the input has focus and Display Mode is set to popup Down arrow
Close the popup and focus the input, when Display Mode is set to popup Escape
Focus the next element
Tab
When the Display Mode is set to popup and the last element is focused, pressing Tab moves focus to the first element.
Focus the previous element
Shift+Tab
When the Display Mode is set to popup and the first element is focused, pressing Tab moves focus to the last element.
Move focus to the same day of the previous week Up arrow
Move focus to the same day of the next week Down arrow
Move focus to the previous day Left arrow
Move focus to the next day Right arrow
Move focus to the first day of the current week Home
Move focus to the last day of the current week End
Change the grid of dates to the previous month Page Up
Change the grid of dates to the next month Page Down
Change the grid of dates to the previous year Shift+Page Up
Change the grid of dates to the next year Shift+Page Down
Select the focused date, when Show Time is off Enter or Space
Select the focused date, when Show Time is on Enter or Space, then Done
