4 Importing a Workbook File
You can import a workbook file exported from the same version (or earlier version) as your Oracle Analytics environment. For example, if you exported a workbook from an Oracle Analytics environment that includes the May 2025 update, then you can import it into other Oracle Analytics environments that include the May 2025 update or a later update such as July 2025. You might experience unexpected results if you import a workbook that was exported from a more recent update of Oracle Analytics. For example, if you export a workbook from an Oracle Analytics environment that includes the September 2025 update, then Oracle doesn’t recommend that you import this workbook into an Oracle Analytics environment that includes an earlier update such as June 2025.
To import a workbook file (.dva file) into Oracle Analytics Cloud:
