Remap Fields Used in Calculated Measures
Prerequisite
To ensure you don't overwrite the sample dashboards delivered with Construction and Engineering Analytics with your customizations:
- Open the sample dashboard you plan to customize
- Click Save As and store it in separate folder of your choice in the catalog.
Remapping Calculated Measures
To remap fields used in a calculated measure:
- In the Data panel, expand My Calculations, and then, select the calculated measure you want to update.
For example, select the # Project Count measure.
- Right click # Project Count and then select Edit Calculation.
- In the Edit Calculation dialog box, delete the current field, and then drag and drop the field you want to replace with.
For example, delete the Project ID field, and drag and drop the Project Object ID field to replace in the calculated measure.
- Click Save.
