Remap Fields Used in Data Visualizations
Prerequisite
To ensure you don't overwrite the sample dashboards delivered with Construction and Engineering Analytics with your customizations:
- Open the sample dashboard you plan to customize.
- Click Save As and store it in a separate folder of your choice in the catalog.
Remapping Fields
To re-point or remap fields used in a data visualization:
- Select a target visualization.
- In the Data panel, select the field you will use to replace the current field in the selected visualization.
For example, replace Project Cost 21 column in the pivot table with the Non-Commitment Costs field.
- Drag and drop the Non-Commitment Costs field on the Project Cost 21.
- Save the workbook.
