Workflow Sample Dashboard
Description: The data displayed in the Aconex - Workflow dashboard, and in any out-of-the-box or custom dashboard is based on the projects that you have access in Aconex.
Use the Aconex - Workflow dashboard to discover information such as, (but not limited to):
  • Identify already delayed Workflow document reviews across project portfolio.
  • Know organizations holding on the Workflow document reviews for longer than N days.
  • Find the projects with max overdue workflow document review/steps.
  • View KPIs, track workflow document review status, etc.
You can also create your own data sets and/or data flows to:
  • Classify workflows as low to extreme delay.
  • Create use cases that need linking other subject areas with workflows, etc.
Number of Canvases: 3
Default Canvas: Activity
Canvas/Dashboard Name: Workflow Sample Dashboard
Data Source(s): Aconex
Subject Area:
Datasets:
Dashboard
Workflow - Overview Tab
Workflow - Activity Tab
