Documents Sample Dashboard
Description: The data displayed in the Aconex - Documents sample dashboard, and in any out-of-the-box or custom dashboard is based on the projects that you have access in Aconex.
Use the Aconex - Documents dashboard to discover information such as, (but not limited to):
- Compare statistics across the project portfolio such as documents registered by type, status, discipline, organizations, etc.
- Track activity such as organizations that modified or transmitted the most/least docs
- View document details, etc.
You can also create your own data sets and/or data flows to:
- Find if you have shared/transmitted the latest document revision/version, etc.
- Achieve custom dashboard requirements.
- Create use cases that need links with Documents, etc.
Number of Canvases: 4
Default Canvas: Activity
Canvas/Dashboard Name: Documents Sample Dashboard
Data Source(s): Aconex
Subject Area: Aconex – Documents, Aconex - Workflow
Datasets:
Dashboard
