Aconex - Documents
Description: The data displayed in the Aconex - Documents subject area, and in any out-of-the-box or custom dashboard is based on the projects that you have access in Aconex.
Use the Aconex - Documents subject area to discover information such as, (but not limited to):
  • Compare statistics across the project portfolio such as documents registered by type, status, discipline, organizations, etc.
  • Track activity such as organizations that modified or transmitted the most/least docs
  • View document details, etc.
You can also create your own data sets and/or data flows to:
  • Find if you have shared/transmitted the latest document revision/version, etc.
  • Achieve custom dashboard requirements using Document Project Fields
Subject Area: Aconex - Documents
Folder SubFolder Field Name Dimension/Fact Description
Project General (Project)
Project General - (Project) Project Name Dimension Displays a list of all projects that the current user has access to.
Project General - (Project) Datasource Id Dimension Datasource Id
Project General - (Project) Project Id Dimension The unique ID of the project in Aconex
Documents General - (Documents)
Documents General - (Documents) Document Unique ID Dimension The unique ID of the document in Aconex.
Documents General - (Documents) Document Number Dimension A unique alphanumeric number assigned to a document in the doc registered. The document number can be auto-generated or entered by a user.
Documents General - (Documents) Document Discipline Dimension The discipline of the document. For example, Architectural, Electrical, Mechanical, etc. This can be relabeled by the user with access to the project.
Documents General - (Documents) Doc Registering Org Dimension The name of the organization who registered the given document in the Aconex document register.
Documents General - (Documents) My Organization Dimension The logged-in user's organization name.
Documents General - (Documents) Percent Complete Dimension The percentage of workflow completed currently.
Documents General - (Documents) Review Source Dimension The Workflow number in which given doc is attached.
Documents General - (Documents) Review Status Dimension The review status of the document in the workflow.
Documents General - (Documents) Revision Dimension The document revision.
Documents General - (Documents) Doc Status Dimension The document's status. For example, Draft, For Review, Rejected, Approved, etc.
Documents General - (Documents) Document Title Dimension The title of the document.
Documents General - (Documents) Transmitted Dimension Indicates if the document was transmitted.
Documents General - (Documents) Type Dimension The document type. For example, a drawing, timesheet, checklist, etc.
Documents General - (Documents) Version Dimension The system-generated version(s) of the document.
Documents General - (Documents) Current Dimension
Indicates if the document revision and version is current.
Note: It is not recommended for use as Current Revision or Current Version attributes as it may return duplicate records or incorrect output.
Documents General - (Documents) Current Version Dimension The latest system-generated version of the document.
Documents General - (Documents) Current Revision Dimension The most recent saved revision of the document.
Documents General - (Documents) Number of Markups Dimension
The number of markups included in the document version.
Documents General - (Documents) Modified By Dimension The name of the user who added the document to the doc. register.
Documents General - (Documents) Created By Dimension The name of the user who initially created the document.
Documents General - (Documents) Transmittal In Dimension Holds the mail ID of transmittal document.
Documents General - (Documents) Trading Name Dimension The trading name associated with an organization.
Documents Dates - (Documents)
Documents Dates - (Documents) Date Approved Dimension The date on which the document was approved in the workflow.
Documents Dates - (Documents) Date Created Dimension The date filled in by the user when registering a document in doc register.
Documents Dates - (Documents) Date For Review Dimension The date on which the document was expected to be reviewed.
Documents Dates - (Documents) Date Modified Dimension Date registered. Set automatically when a document version is created in document register.
Documents Dates - (Documents) Date Reviewed Dimension The date on which the document was actually reviewed.
Documents Dates - (Documents) Milestone Date Dimension The milestone date associated with the document.
Documents Dates - (Documents) Planned Submission Date Dimension The planned submission date associated with the document.
Documents Dates - (Documents) Revision Date Dimension The date when the document was revised.
Documents Dates - (Documents) Last Updated Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dates - (Documents) Markup Last Modified Date Dimension The date on which the document was last marked up with comments.
Documents Dynamic Attributes - (Documents)
Documents Dynamic Attributes - (Documents) As Built Required Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Attribute 1 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Attribute 2 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Attribute 3 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Attribute 4 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Category Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Check 1 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Check 2 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Comments Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Comments 2 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Contract Deliverable Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Contract No Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Contractor Doc No Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Contractor Rev Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Date 1 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Date 2 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Last Updated Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Markup Last Modified Date Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Package No Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Project Object Id Dimension Unique Id of the Project.
Documents Dynamic Attributes - (Documents) Project Field 1 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Project Field 2 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Project Field 3 Dimension A dynamic attribute that can be relabeled on given project as required.
Documents Dynamic Attributes - (Documents) Select List 1 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 10 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 2 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 3 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 4 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 5 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 6 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 7 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 8 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Select List 9 Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Tag No Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) VDR Code Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Vendor Doc No Dimension A dynamic attribute that can be relabeled on given project as required.
Document Dynamic Attributes - (Documents) Vendor Rev Dimension A dynamic attribute that can be relabeled on given project as required.
Project Fields Text (Common)
The contents of this folder depend on the project fields selected for your organization in the CEI Administration application. A maximum of 50 Aconex project fields (common + non-common) of Text data type, common to several projects, can be displayed.
Contact your CEI Administrator if you want to include or exclude any project fields in CEI to create your custom dashboard.
Project Fields Date (Common)
The contents of this folder depend on the project fields selected for your organization in the CEI Administration application. A maximum of 50 Aconex project fields (common + non-common) of Date data type, common to several projects, can be displayed.
Project Fields Number (Common)
The contents of this folder depend on the project fields selected for your organization in the CEI Administration application. A maximum of 50 Aconex project fields (common + non-common) of Number data type, common to several projects, can be displayed.
Project Fields Text (Non-Common)
The contents of this folder depend on the project fields selected for your organization in the CEI Administration application. A maximum of 50 Aconex project fields (common + non-common) of Text data type, specific to individual projects, can be displayed.
Project Fields Date (Non-Common)
The contents of this folder depend on the project fields selected for your organization in the CEI Administration application. A maximum of 50 Aconex project fields (common + non-common) of Date data type, specific to individual projects, can be displayed.
Project Fields Number (Non-Common)
The contents of this folder depend on the project fields selected for your organization in the CEI Administration application. A maximum of 50 Aconex project fields (common + non-common) of Number data type, specific to individual projects, can be displayed.
Mails General (Mails)
Mails General (Mails) Mail Number Dimension Mail number (unique for each mail)
Mails General (Mails) Mail Status Dimension Mail status (eg. Overdue /Outstanding /Responded /Closed-Out)
Mails General (Mails) Mail Type Dimension Mail Type
Mails General (Mails) To Organization Dimension Mail recipient's organization name
Mails General (Mails) From Organization Dimension Mail sender's organization name.
Files General - (Files)
Files General - (Files) File Unique ID Dimension A unique alphanumeric ID for each file.
Files General - (Files) File Name Dimension The file name of the document in Aconex document register.
Files General - (Files) File Size Dimension The file size of the document in Aconex document register.
Files General - (Files) File Type Dimension The file format of the document in the Aconex document register. For example, .pdf, .xlsx, etc.
Fact - Aconex Documents Fact - Documents
Fact - Aconex Documents Fact - Documents # of Registered Documents Fact
The number of documents registered / available in the ACX doc register.
Fact - Aconex Documents Fact - Documents # of Docs (Transmittals Sent) Fact
The count of documents attached in transmittals sent.
Fact - Aconex Documents Fact - Documents # of Docs (Transmittals Received) Fact
The count of documents attached in transmittals received.
Fact - Aconex Documents Fact - Documents # of Docs (Transmittals Sent + Received) Fact
The total number of documents attached in the transmittals Sent and Received.
Fact - Aconex Documents Fact - Documents # of Registered Document Revisions Fact The total number of document revisions registered /available in the document register across all projects.
Fact - Aconex Documents Fact - Documents # of Registered Document Versions Fact The total number of document versions registered /available in the document register across all projects.
