P6 - Resource Assignment / Primavera - Resource Assignment
Description: Use this subject area to analyze resource assignment details for costs and units. This subject area includes information on planned, actual, remaining, staffed, unstaffed, and at completion costs and units.
Folder Subfolder Field Name Dimension/ Fact / Lookup Description Values Derived From / Calculated By
Resource Cost Account - (Resource)     Resource Cost Accounts
Resource Cost Account - (Resource) Cost Account ID Dimension A short ID assigned to each cost account for identification. Each cost account is uniquely identified by concatenating its own ID together with its parents' IDs. Dim_W_COST_ACCOUNT_D_CostAcct.ACCT_SHORT_NAME
Resource Cost Account - (Resource) Cost Account Name Dimension The name of a cost account. Dim_W_COST_ACCOUNT_D_CostAcct.ACCT_NAME
Resource General - (Resource)     General Resource Information
Resource General - (Resource) Active Dimension Indicates whether the resource is currently active. Nonactive resources may have left the organization but are not deleted from the system since they may have actual hours. Value Derived From : Dim_W_RESOURCE_D_Resource.ACTIVE_FLAG
Resource General - (Resource) Datasource Id Dimension A unique source Id created for the Primavera data source being used. Used to identify data sources when using multiple Primavera data sources. Value Derived From : Dim_W_RESOURCE_D_Resource.DATASOURCE_ID
Resource General - (Resource) Primary Role Name Dimension The name of the role that is assigned as the resource's primary role Value Derived From : Dim_W_RESOURCE_D_Resource.PRIMARY_ROLE_NAME
Resource General - (Resource) Unique Primary Role Id Dimension The unique Id of the role that is assigned as the resource's primary role Value Derived From : Dim_W_RESOURCE_D_Resource.PRIMARY_ROLE_OBJECT_ID
Resource General - (Resource) Resource ID Dimension A short code which uniquely identifies the resource Value Derived From : Dim_W_RESOURCE_D_Resource.RESOURCE_ID
Resource General - (Resource) Resource Name Dimension The name of the resource Value Derived From : Dim_W_RESOURCE_D_Resource.RESOURCE_NAME
Resource General - (Resource) Title Dimension The title of the resource Value Derived From : Dim_W_RESOURCE_D_Resource.RESOURCE_TITLE
Resource General - (Resource) Resource Type Dimension Indicates whether the resource is labor, nonlabor, or material Value Derived From : Dim_W_RESOURCE_D_Resource.RESOURCE_TYPE
Resource Resource Team - (Resource)     Resource Teams
Resource Resource Team - (Resource) Resource Team Name   The name of the Resource Team.
Fact - Primavera - Resource Assignment Folder
Fact - Primavera - Resource Assignment Costs     Costs
Fact - Primavera - Resource Assignment Costs Actual Cost Fact The actual non-overtime plus overtime cost for the resource assignment on the activity. Calculated as Actual Regular Cost plus Actual Overtime Cost. Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.ACTUAL_COST
Fact - Primavera - Resource Assignment Costs Actual Overtime Cost Fact The actual overtime cost for the resource assignment on the activity. Calculated as Actual Overtime Units multiplied by Cost per Time multiplied by Overtime Factor. Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.ACTUAL_OVERTIME_COST
Fact - Primavera - Resource Assignment Costs Actual Regular Cost Fact The actual non-overtime cost for the resource assignment on the activity. Calculated as Actual Regular Units multiplied by Cost per Time. Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.ACTUAL_REGULAR_COST
Fact - Primavera - Resource Assignment Costs At Completion Cost Fact The sum of the actual costs plus remaining costs for the resource assignment on the activity. Calculated as Actual Costs plus Remaining Costs. Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.AT_COMPLETION_COST
Fact - Primavera - Resource Assignment Costs Planned Cost Fact The planned cost of work required for the assignment to be completed. Calculated as Planned Units multiplied by Price per Time. Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.PLANNED_COST
Fact - Primavera - Resource Assignment Costs Remaining Cost Fact The remaining cost for the resource assignment on the activity. Calculated as Remaining Units multiplied by Cost/Time. Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.REMAINING_COST
Fact - Primavera - Resource Assignment Costs Remaining Late Cost Fact Remaining Late Cost Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.REMAINING_LATE_COST
Fact - Primavera - Resource Assignment Costs Staffed Remaining Cost Fact The remaining cost for resource assignments that have a filled role. Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.STAFFED_REMAINING_COST
Fact - Primavera - Resource Assignment Costs Staffed Remaining Late Cost Fact Staffed Remaining Late Cost Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.STAFFED_REMAINING_COST
Fact - Primavera - Resource Assignment Costs Unstaffed Remaining Cost Fact The remaining cost for resource assignments that do not have a filled role. Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.UNSTAFFED_REMAINING_COST
Fact - Primavera - Resource Assignment Costs Unstaffed Remaining Late Cost Fact Unstaffed Remaining Late Cost Value Derived From : Fact_W_RESOURCE_SPREAD_F_Resource_Spread.UNSTAFFED_REMAINING_COST
Fact - Primavera - Resource Assignment Metrics     Metrics
Fact - Primavera - Resource Assignment Metrics # Of Activities Fact # Of Activities count(distinct Fact_W_RESOURCE_SPREAD_F_Resource_Spread.ACTIVITY_WID)
Fact - Primavera - Resource Assignment Metrics # Of Projects Fact # Of Projects count(distinct Fact_W_RESOURCE_SPREAD_F_Resource_Spread.PROJECT_WID)
Fact - Primavera - Resource Assignment Metrics # Of Resources Fact # Of Resources count(distinct Fact_W_RESOURCE_SPREAD_F_Resource_Spread.RESOURCE_WID)
Fact - Primavera - Resource Assignment Units     Units
Fact - Primavera - Resource Assignment Units Actual Overtime Units Fact The actual overtime units worked by the resource on this activity. This value is computed from timesheets when project actuals are applied or may be entered directly by the project manager. sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.ACTUAL_OVERTIME_UNITS)
Fact - Primavera - Resource Assignment Units Actual Regular Units Fact The actual nonovertime units worked by the resource on this activity. This value is computed from timesheets when project actuals are applied or may be entered directly by the project manager. sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.ACTUAL_REGULAR_UNITS)
Fact - Primavera - Resource Assignment Units Actual Units Fact The sum of the actual non-overtime and the overtime units worked by the resource on the activity. sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.ACTUAL_UNITS)
Fact - Primavera - Resource Assignment Units At Completion Units Fact The sum of the actual units and remaining units for the resource assignment on the activity. Calculated as Actual Units plus Remaining Units. sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.AT_COMPLETION_UNITS)
Fact - Primavera - Resource Assignment Units Planned Units Fact The planned units of work for the resource assignment on the activity. sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.PLANNED_UNITS)
Fact - Primavera - Resource Assignment Units Remaining Late Units Fact Remaining Late Units sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.REMAINING_LATE_UNITS)
Fact - Primavera - Resource Assignment Units Remaining Units Fact The remaining units of work to be performed by the resource on the activity. Calculated as Planned Units minus Actual Units. sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.REMAINING_UNITS)
Fact - Primavera - Resource Assignment Units Staffed Remaining Late Units Fact Staffed Remaining Late Units sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.STAFFED_REMAINING_LATE_UNITS)
Fact - Primavera - Resource Assignment Units Staffed Remaining Units Fact The remaining units for resource assignments that have filled a role. sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.STAFFED_REMAINING_UNITS)
Fact - Primavera - Resource Assignment Units Unstaffed Remaining Late Units Fact Unstaffed Remaining Late Units sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.UNSTAFFED_REMAINING_LATE_UNITS)
Fact - Primavera - Resource Assignment Units Unstaffed Remaining Units Fact The remaining units for resource assignments that have not filled a role. sum(Fact_W_RESOURCE_SPREAD_F_Resource_Spread.UNSTAFFED_REMAINING_UNITS)
Assignment Role Folder
Assignment Role General - (Role)     General Role Information
Assignment Role General - (Role) Is Primary Role Dimension Is Primary Role Value Derived From : Dim_W_RESOURCE_ROLE_D_Resource_Role.IS_PRIMARY_ROLE
Assignment Role General - (Role) Role ID Dimension The role the resource is performing on this activity. A resource may be assigned to the same activity more than once, performing different roles. The project manager controls whether the same resource can be assigned to an activity more than once. Value Derived From : Dim_W_ROLE_D_Role.ROLE_SHORT_NAME
Assignment Role General - (Role) Role Name Dimension The role the resource is performing on this activity. A resource may be assigned to the same activity more than once, performing different roles. The project manager controls whether the same resource can be assigned to an activity more than once. Value Derived From : Dim_W_ROLE_D_Role.ROLE_NAME
Assignment Role Role Hierarchy - (Role)     Role Hierarchy
Assignment Role Role Hierarchy - (Role) Full Path Name Dimension Full Path Name Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.FULL_PATH_NAME
Assignment Role Role Hierarchy - (Role) Role Level Dimension Role Level Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.LVL
Assignment Role Role Hierarchy - (Role) Role Name Dimension Role Name Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME
Assignment Role Role Hierarchy - (Role) Role Name Level 1 Dimension Role Name Level 1 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV1
Assignment Role Role Hierarchy - (Role) Role Name Level 10 Dimension Role Name Level 10 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV10
Assignment Role Role Hierarchy - (Role) Role Name Level 11 Dimension Role Name Level 11 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV11
Assignment Role Role Hierarchy - (Role) Role Name Level 12 Dimension Role Name Level 12 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV12
Assignment Role Role Hierarchy - (Role) Role Name Level 13 Dimension Role Name Level 13 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV13
Assignment Role Role Hierarchy - (Role) Role Name Level 14 Dimension Role Name Level 14 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV14
Assignment Role Role Hierarchy - (Role) Role Name Level 15 Dimension Role Name Level 15 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV15
Assignment Role Role Hierarchy - (Role) Role Name Level 16 Dimension Role Name Level 16 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV16
Assignment Role Role Hierarchy - (Role) Role Name Level 17 Dimension Role Name Level 17 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV17
Assignment Role Role Hierarchy - (Role) Role Name Level 18 Dimension Role Name Level 18 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV18
Assignment Role Role Hierarchy - (Role) Role Name Level 19 Dimension Role Name Level 19 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV19
Assignment Role Role Hierarchy - (Role) Role Name Level 2 Dimension Role Name Level 2 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV2
Assignment Role Role Hierarchy - (Role) Role Name Level 20 Dimension Role Name Level 20 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV20
Assignment Role Role Hierarchy - (Role) Role Name Level 21 Dimension Role Name Level 21 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV21
Assignment Role Role Hierarchy - (Role) Role Name Level 22 Dimension Role Name Level 22 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV22
Assignment Role Role Hierarchy - (Role) Role Name Level 23 Dimension Role Name Level 23 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV23
Assignment Role Role Hierarchy - (Role) Role Name Level 24 Dimension Role Name Level 24 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV24
Assignment Role Role Hierarchy - (Role) Role Name Level 3 Dimension Role Name Level 3 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV3
Assignment Role Role Hierarchy - (Role) Role Name Level 4 Dimension Role Name Level 4 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV4
Assignment Role Role Hierarchy - (Role) Role Name Level 5 Dimension Role Name Level 5 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV5
Assignment Role Role Hierarchy - (Role) Role Name Level 6 Dimension Role Name Level 6 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV6
Assignment Role Role Hierarchy - (Role) Role Name Level 7 Dimension Role Name Level 7 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV7
Assignment Role Role Hierarchy - (Role) Role Name Level 8 Dimension Role Name Level 8 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV8
Assignment Role Role Hierarchy - (Role) Role Name Level 9 Dimension Role Name Level 9 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_NAME_LV9
Assignment Role Role Hierarchy - (Role) Role Unique ID Dimension Role Unique ID Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 1 Dimension Role Unique ID Level 1 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV1
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 10 Dimension Role Unique ID Level 10 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV10
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 11 Dimension Role Unique ID Level 11 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV11
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 12 Dimension Role Unique ID Level 12 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV12
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 13 Dimension Role Unique ID Level 13 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV13
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 14 Dimension Role Unique ID Level 14 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV14
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 15 Dimension Role Unique ID Level 15 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV15
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 16 Dimension Role Unique ID Level 16 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV16
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 17 Dimension Role Unique ID Level 17 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV17
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 18 Dimension Role Unique ID Level 18 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV18
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 19 Dimension Role Unique ID Level 19 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV19
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 2 Dimension Role Unique ID Level 2 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV2
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 20 Dimension Role Unique ID Level 20 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV20
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 21 Dimension Role Unique ID Level 21 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV21
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 22 Dimension Role Unique ID Level 22 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV22
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 23 Dimension Role Unique ID Level 23 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV23
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 24 Dimension Role Unique ID Level 24 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV24
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 3 Dimension Role Unique ID Level 3 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV3
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 4 Dimension Role Unique ID Level 4 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV4
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 5 Dimension Role Unique ID Level 5 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV5
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 6 Dimension Role Unique ID Level 6 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV6
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 7 Dimension Role Unique ID Level 7 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV7
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 8 Dimension Role Unique ID Level 8 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV8
Assignment Role Role Hierarchy - (Role) Role Unique ID Level 9 Dimension Role Unique ID Level 9 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_OBJECT_ID_LV9
Assignment Role Role Hierarchy - (Role) Role Short Name Dimension Role Short Name Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID
Assignment Role Role Hierarchy - (Role) Role ID Level 1 Dimension Resource Role Short Name Level 1 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV1
Assignment Role Role Hierarchy - (Role) Role ID Level 10 Dimension Role ID Level 10 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV10
Assignment Role Role Hierarchy - (Role) Role ID Level 11 Dimension Role ID Level 11 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV11
Assignment Role Role Hierarchy - (Role) Role ID Level 12 Dimension Role ID Level 12 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV12
Assignment Role Role Hierarchy - (Role) Role ID Level 13 Dimension Role ID Level 13 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV13
Assignment Role Role Hierarchy - (Role) Role ID Level 14 Dimension Role ID Level 14 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV14
Assignment Role Role Hierarchy - (Role) Role ID Level 15 Dimension Role ID Level 15 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV15
Assignment Role Role Hierarchy - (Role) Role ID Level 16 Dimension Role ID Level 16 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV16
Assignment Role Role Hierarchy - (Role) Role ID Level 17 Dimension Role ID Level 17 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV17
Assignment Role Role Hierarchy - (Role) Role ID Level 18 Dimension Role ID Level 18 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV18
Assignment Role Role Hierarchy - (Role) Role ID Level 19 Dimension Role ID Level 19 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV19
Assignment Role Role Hierarchy - (Role) Role ID Level 2 Dimension Role ID Level 2 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV2
Assignment Role Role Hierarchy - (Role) Role ID Level 20 Dimension Role ID Level 20 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV20
Assignment Role Role Hierarchy - (Role) Role ID Level 21 Dimension Role ID Level 21 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV21
Assignment Role Role Hierarchy - (Role) Role ID Level 22 Dimension Role ID Level 22 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV22
Assignment Role Role Hierarchy - (Role) Role ID Level 23 Dimension Role ID Level 23 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV23
Assignment Role Role Hierarchy - (Role) Role ID Level 24 Dimension Role ID Level 24 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV24
Assignment Role Role Hierarchy - (Role) Role ID Level 3 Dimension Role ID Level 3 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV3
Assignment Role Role Hierarchy - (Role) Role ID Level 4 Dimension Role ID Level 4 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV4
Assignment Role Role Hierarchy - (Role) Role ID Level 5 Dimension Role ID Level 5 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV5
Assignment Role Role Hierarchy - (Role) Role ID Level 6 Dimension Role ID Level 6 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV6
Assignment Role Role Hierarchy - (Role) Role ID Level 7 Dimension Role ID Level 7 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV7
Assignment Role Role Hierarchy - (Role) Role ID Level 8 Dimension Role ID Level 8 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV8
Assignment Role Role Hierarchy - (Role) Role ID Level 9 Dimension Role ID Level 9 Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROLE_ID_LV9
Assignment Role Role Hierarchy - (Role) Root Level Role Name Dimension Root Level Role Name Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROOT_LEVEL_ROLE_NAME
Assignment Role Role Hierarchy - (Role) Root Level Role Unique ID Dimension Root Level Role Unique ID Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROOT_LEVEL_ROLE_OBJECT_ID
Assignment Role Role Hierarchy - (Role) Root Level Role Short Name Dimension Root Level Role Short Name Oracle Primavera P6 Data Warehouse.Catalog.dbo.Dim_W_ROLE_HIERARCHY_D_RoleHierarchy.ROOT_LEVEL_ROLE_ID
