P6 - Resource Assignment History / Primavera - Resource Assignment History
Enter topic description here.
Description: Use this subject area to analyze daily resource assignment-level history, including changes to both facts and dimensions to help you understand changes over time. This subject area requires project specific configuration in P6.
Folder Subfolder Field Name Dimension/ Fact / Lookup Description Values Derived From / Calculated By
Resource Cost Account - (Resource)     Resource Cost Accounts
Resource Cost Account - (Resource) Cost Account ID Dimension A short ID assigned to each cost account for identification. Each cost account is uniquely identified by concatenating its own ID together with its parents' IDs. Value Derived From : Dim_W_COST_ACCOUNT_HD_CostAcct.ACCT_SHORT_NAME
Resource Cost Account - (Resource) Cost Account Name Dimension The name of a cost account. Value Derived From : Dim_W_COST_ACCOUNT_HD_CostAcct.ACCT_NAME
Resource Cost Account - (Resource) Current Flag Dimension Indicates if a record is current (1,0) Value Derived From : Dim_W_COST_ACCOUNT_HD_CostAcct.CURRENT_FLAG
Resource Cost Account - (Resource) Effective End Date Dimension The end date this version of the record is effective Value Derived From : Dim_W_COST_ACCOUNT_HD_CostAcct.EFFECTIVE_END_DATE
Resource Cost Account - (Resource) Effective Start Date Dimension The start date this version of the record is effective Value Derived From : Dim_W_COST_ACCOUNT_HD_CostAcct.EFFECTIVE_START_DATE
Resource General - (Resource)     General Resource Information
Resource General - (Resource) Active Dimension Indicates whether the resource is currently active. Nonactive resources may have left the organization but are not deleted from the system since they may have actual hours. Value Derived From : Dim_W_RESOURCE_HD_Resource.ACTIVE_FLAG
Resource General - (Resource) Current Flag Dimension Indicates if a record is current (1,0) Value Derived From : Dim_W_RESOURCE_HD_Resource.CURRENT_FLAG
Resource General - (Resource) Datasource Id Dimension A unique source Id created for the Primavera data source being used. Used to identify data sources when using multiple Primavera data sources. Value Derived From : Dim_W_RESOURCE_HD_Resource.DATASOURCE_ID
Resource General - (Resource) Effective End Date Dimension The end date this version of the record is effective Value Derived From : Dim_W_RESOURCE_HD_Resource.EFFECTIVE_END_DATE
Resource General - (Resource) Effective Start Date Dimension The start date this version of the record is effective Value Derived From : Dim_W_RESOURCE_HD_Resource.EFFECTIVE_START_DATE
Resource General - (Resource) Primary Role Name Dimension The name of the role that is assigned as the resource's primary role. Value Derived From : Dim_W_RESOURCE_HD_Resource.PRIMARY_ROLE_NAME
Resource General - (Resource) Unique Primary Role Id Dimension The unique Id of the role that is assigned as the resource's primary role. Value Derived From : Dim_W_RESOURCE_HD_Resource.PRIMARY_ROLE_OBJECT_ID
Resource General - (Resource) Resource ID Dimension A short code which uniquely identifies the resource. Value Derived From : Dim_W_RESOURCE_HD_Resource.RESOURCE_ID
Resource General - (Resource) Resource Name Dimension The name of the resource Value Derived From : Dim_W_RESOURCE_HD_Resource.RESOURCE_NAME
Resource General - (Resource) Title Dimension The title of the resource Value Derived From : Dim_W_RESOURCE_HD_Resource.RESOURCE_TITLE
Resource General - (Resource) Resource Type Dimension Indicates whether the resource is labor, nonlabor, or material. Value Derived From : Dim_W_RESOURCE_HD_Resource.RESOURCE_TYPE
Resource Location - (Resource)     Resource Location
Resource Location - (Resource) Address Line 1 Dimension The first line of the address Value Derived From : Dim_W_RESOURCE_HD_Resource.ADDRESS_LINE1
Resource Location - (Resource) Address Line 2 Dimension The second line of the address Value Derived From : Dim_W_RESOURCE_HD_Resource.ADDRESS_LINE2
Resource Location - (Resource) City Name Dimension The city name for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.CITY_NAME
Resource Location - (Resource) Country Code Dimension The country code for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.COUNTRY_CODE
Resource Location - (Resource) Country Name Dimension The country name for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.COUNTRY_NAME
Resource Location - (Resource) Latitude Dimension The latitude for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.LATITUDE
Resource Location - (Resource) Location Name Dimension The name of the location Value Derived From : Dim_W_RESOURCE_HD_Resource.LOCATION_NAME
Resource Location - (Resource) Location Type Dimension Location Type Value Derived From : Dim_W_RESOURCE_HD_Resource.LOCATION_TYPE
Resource Location - (Resource) Longitude Dimension The longitude for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.LONGITUDE
Resource Location - (Resource) Municipality Name Dimension The municipality name for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.MUNICIPALITY_NAME
Resource Location - (Resource) Postal Code Dimension The postal code for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.POSTAL_CODE
Resource Location - (Resource) State/Province Code Dimension The state abbreviation for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.STATE_CODE
Resource Location - (Resource) State/Province Name Dimension The state name for this Location Value Derived From : Dim_W_RESOURCE_HD_Resource.STATE_NAME
Fact - Primavera - Resource Assignment History Folder
Fact - Primavera - Resource Assignment History Costs     Costs
Fact - Primavera - Resource Assignment History Costs Actual Cost Fact The actual non-overtime plus overtime cost for the resource assignment on the activity. Calculated as Actual Regular Cost plus Actual Overtime Cost. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.ACTUAL_COST)
Fact - Primavera - Resource Assignment History Costs Actual Overtime Cost Fact The actual overtime cost for the resource assignment on the activity. Calculated as Actual Overtime Units multiplied by Cost per Time multiplied by Overtime Factor. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.ACTUAL_OVERTIME_COST)
Fact - Primavera - Resource Assignment History Costs Actual Regular Cost Fact The actual non-overtime cost for the resource assignment on the activity. Calculated as Actual Regular Units multiplied by Cost per Time. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.ACTUAL_REGULAR_COST)
Fact - Primavera - Resource Assignment History Costs At Completion Cost Fact The sum of the actual costs plus remaining costs for the resource assignment on the activity. Calculated as Actual Costs plus Remaining Costs. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.AT_COMPLETION_COST)
Fact - Primavera - Resource Assignment History Costs Period Actual Cost Fact Period Actual Cost sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.PERIOD_ACTUAL_COST)
Fact - Primavera - Resource Assignment History Costs Planned Cost Fact The planned cost of work required for the assignment to be completed. Calculated as Planned Units multiplied by Price per Time. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.PLANNED_COST)
Fact - Primavera - Resource Assignment History Costs Remaining Cost Fact The remaining cost for the resource assignment on the activity. Calculated as Remaining Units multiplied by Cost/Time. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.REMAINING_COST)
Fact - Primavera - Resource Assignment History Costs Remaining Late Cost Fact Remaining Late Cost sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.REMAINING_LATE_COST)
Fact - Primavera - Resource Assignment History Costs Staffed Remaining Cost Fact The remaining cost for resource assignments that have a filled role. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.STAFFED_REMAINING_COST)
Fact - Primavera - Resource Assignment History Costs Staffed Remaining Late Cost Fact Staffed Remaining Late Cost sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.STAFFED_REMAINING_LATE_COST)
Fact - Primavera - Resource Assignment History Costs Unstaffed Remaining Cost Fact The remaining cost for resource assignments that do not have a filled role. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.UNSTAFFED_REMAINING_COST)
Fact - Primavera - Resource Assignment History Costs Unstaffed Remaining Late Cost Fact Unstaffed Remaining Late Cost sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.UNSTAFFED_REMAINING_LATE_COST)
Fact - Primavera - Resource Assignment History Metrics     Metrics
Fact - Primavera - Resource Assignment History Metrics # Of Activities Fact # Of Activities count(distinct Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.ACTIVITY_WID)
Fact - Primavera - Resource Assignment History Metrics # Of Projects Fact # Of Projects count(distinct Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.PROJECT_WID)
Fact - Primavera - Resource Assignment History Metrics # Of Resources Fact # Of Resources count(distinct Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.RESOURCE_WID)
Fact - Primavera - Resource Assignment History Units     Units
Fact - Primavera - Resource Assignment History Units Actual Overtime Units Fact The actual overtime units worked by the resource on this activity. This value is computed from timesheets when project actuals are applied or may be entered directly by the project manager. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.ACTUAL_OVERTIME_UNITS)
Fact - Primavera - Resource Assignment History Units Actual Regular Units Fact The actual nonovertime units worked by the resource on this activity. This value is computed from timesheets when project actuals are applied or may be entered directly by the project manager. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.ACTUAL_REGULAR_UNITS)
Fact - Primavera - Resource Assignment History Units Actual Units Fact The sum of the actual non-overtime and the overtime units worked by the resource on the activity. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.ACTUAL_UNITS)
Fact - Primavera - Resource Assignment History Units At Completion Units Fact The sum of the actual units and remaining units for the resource assignment on the activity. Calculated as Actual Units plus Remaining Units. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.AT_COMPLETION_UNITS)
Fact - Primavera - Resource Assignment History Units Period Actual Units Fact Period Actual Units sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.PERIOD_ACTUAL_UNITS)
Fact - Primavera - Resource Assignment History Units Planned Units Fact The planned units of work for the resource assignment on the activity. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.PLANNED_UNITS)
Fact - Primavera - Resource Assignment History Units Remaining Late Units Fact Remaining Late Units sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.REMAINING_LATE_UNITS)
Fact - Primavera - Resource Assignment History Units Remaining Units Fact The remaining units of work to be performed by the resource on the activity. Calculated as Planned Units minus Actual Units. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.REMAINING_UNITS)
Fact - Primavera - Resource Assignment History Units Staffed Remaining Late Units Fact Staffed Remaining Late Units sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.STAFFED_REMAINING_LATE_UNITS)
Fact - Primavera - Resource Assignment History Units Staffed Remaining Units Fact The remaining units for resource assignments that have filled a role. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.STAFFED_REMAINING_UNITS)
Fact - Primavera - Resource Assignment History Units Unstaffed Remaining Late Units Fact Unstaffed Remaining Late Units sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.UNSTAFFED_REMAINING_LATE_UNITS)
Fact - Primavera - Resource Assignment History Units Unstaffed Remaining Units Fact The remaining units for resource assignments that have not filled a role. sum(Fact_W_ASSIGNMENT_SPREAD_HF_Assignment_Spread.UNSTAFFED_REMAINING_UNITS)
Resource Assignment Folder
Resource Assignment Dates - (Resource Assignment)
Resource Assignment Dates - (Resource Assignment) Actual Finish Dimension The date on which the assignment actually finished Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.ACTUAL_FINISH_DATE
Resource Assignment Dates - (Resource Assignment) Actual Start Dimension The date on which the assignment actually started Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.ACTUAL_START_DATE
Resource Assignment Dates - (Resource Assignment) Effective End Date Dimension The end date this version of the record is effective Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.EFFECTIVE_END_DATE
Resource Assignment Dates - (Resource Assignment) Effective Start Date Dimension The start date this version of the record is effective Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.EFFECTIVE_START_DATE
Resource Assignment Dates - (Resource Assignment) Planned Finish Dimension The date the assignment is scheduled to be finished. Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.PLANNED_FINISH_DATE
Resource Assignment Dates - (Resource Assignment) Planned Start Dimension The date work on the assignment is scheduled to begin. Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.PLANNED_START_DATE
Resource Assignment Dates - (Resource Assignment) Remaining Finish Dimension The date the assignment is scheduled to be finished. This date can be updated manually by the user. Before the activity is started, this date is the same as the Planned Finish date. Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.REMAINING_FINISH_DATE
Resource Assignment Dates - (Resource Assignment) Remaining Start Dimension The date the assignment is scheduled to begin. This date can be updated manually by the user. Before the activity is started, this date is the same as the Planned Start date. Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.REMAINING_START_DATE
Resource Assignment General - (Resource Assignment)     General Resource Assignment Information
Resource Assignment General - (Resource Assignment) Current Flag Dimension Indicates if a record is current (1,0) Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.CURRENT_FLAG
Resource Assignment General - (Resource Assignment) Role Name Dimension The name of the resource for this assignment Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.ROLE_NAME
Resource Assignment General - (Resource Assignment) Resource Name Dimension The name of the role for this assignment Value Derived From : Dim_W_ASSIGNMENT_HD_Assignment.RESOURCE_NAME
