Set the project default cost account
You can specify a project's default cost account. This cost account will be used for resource assignments to activities and project expenses in the open project.
- Choose Enterprise, Projects and display Project Details.
- Select the project to which you want to assign a default cost account.
- Click the Defaults tab.
- In the Defaults for New Activities section, click
in the Cost Account field.
- Select the cost account you want to assign as the default, then click the Select button.
The default cost account is only used for new resource assignments to activities and new project expenses. Changing this setting does not affect existing resource assignments to activities or existing project expenses.
