Cut and paste cost accounts
  1. Choose Enterprise, Cost Accounts. Click the Cost Account ID column label to display the cost accounts hierarchy. An outline symbol in the Cost Account ID column label indicates a hierarchy display.
  2. Select the cost account you want to cut and paste, then click Cut.
  3. Select the cost account to which you want to add the cut account, then click Paste.
    When you cut and paste a cost account, the account's activity and project assignments are also pasted.
