Copy and paste cost accounts
  1. Choose Enterprise, Cost Accounts. Click the Cost Account ID column label to display the cost accounts hierarchy. An outline symbol in the Cost Account ID column label indicates a hierarchy display.
  2. Select the cost account you want to copy, then click Copy.
  3. Select the cost account to which you want to add the copy, then click Paste.
    When you copy and paste a cost account, the cost account's activity and project assignments are not copied.
