Delete a cost account
  1. Choose Enterprise, Cost Accounts.
  2. Select the cost account you want to delete, then click Del./Merge. If activities or projects are assigned to the cost account, the Cost Account in Use dialog box is displayed. To delete the cost account and specify a replacement cost account, choose Select Replacement Account, click OK, then select a replacement account. To delete the cost account without specifying a replacement cost account, choose Delete Account(s), then click OK.
