Edit a cost account
- Choose Enterprise, Cost Accounts. Click the Cost Account ID column label to display the cost accounts hierarchy. An outline symbol in the Cost Account ID column label indicates a hierarchy display.
- Select the cost account you want to edit.
- To change the cost account's position in the hierarchy, click the appropriate arrow buttons.
- Type a new cost account ID.
- Type a new cost account name.
If you change a cost account's ID or name, your change applies to all activity assignments.
