Add activities in the Activity Network
- In the Activity Network, select the group band or another activity box within the group band into which you want to add the new activity, then click
on the Edit toolbar or choose Edit, Add. Depending on your user preferences, the New Activity wizard might start and help you add an activity.Note:
If activities are not grouped in the Activity Network, the activity is added to the bottom of the Activity Network.
