Add activities in the Activity Table
- Select an activity within the group to which you want to add a new activity. Click
on the Edit toolbar or choose Edit. The new activity is placed according to the sorting options selected for the layout. Depending on your user preferences, the New Activity wizard might start and help you add an activity.
