Define general activity information
- Choose Project, Activities, then select the activity whose general information you want to define.
- Display Activity Details, then click each tab in Activity Details and enter the corresponding information.
Tip:
To specify which Activity Details you want to display and their order, click the Layout Options bar, then choose Bottom Layout Options.
