Add or modify a Gantt Chart bar filter
To add a filter to a bar
- Display the Gantt Chart, then choose View, Top Layout Options, Bars.
- Select the bar.
- Double-click the Filter column.
- Click New.
- Type a name for the filter.
- In the top row, click the Parameter column and select All of the Following or Any of the Following.
- In the Where row, double-click the Parameter column and select an item to include in the new filter.
- In the Is column, double-click the corresponding field and select the filter's search condition or comparison operator.
- In the Value column, double-click the corresponding field and type or select the value you want to display for the specified field.
- To add another filter field, click Add, then repeat steps 7 through 9 for each field you want to include in the filter.
To modify a bar's filter
You can only modify user-defined filters. You cannot modify the default filters.
- Select the bar.
- Click Modify.
- Change any of the filter criteria.
