Assign a filter to a Gantt Chart bar
- Display the Gantt Chart, then choose View, Top Layout Options, Bars.
- Select the bar.
- Double-click the Filter column.
- Mark the Select checkbox next to each filter you want the bar to represent.
- To preview the new bar filter settings without closing the Bars dialog box, click Apply.
