Assign an issue to an activity
  1. Choose Project, Issues, then select the issue.
  2. Display Issue Details, then click the Details tab.
  3. In the Applies to Activity field, click "", select the activity to which you want to assign the issue, then click the Select button.
    If the threshold monitor generated the selected issue, you cannot assign the issue to an activity or change the issue's activity assignment.
