Assign an issue to a resource
- Choose Project, Issues, then select the issue.
- Display Issue Details, then click the Details tab.
- In the Applies to Resource field, click
, select the resource to which you want to assign the issue, then click the Select button.
If the threshold monitor generated the selected issue, you cannot assign the issue to a resource or change the issue's resource assignment.
