Assign a tracking layout to an issue
When you assign a default tracking layout to an issue, you can quickly view issue details through the Issue Navigator.
  1. Choose Project, Issues, then select the issue.
  2. Display Issue Details, then click the General tab.
  3. In the Tracking Layout field, click "", select the tracking layout you want to assign, then click the Select button.
