Assign notebooks to activities
- Choose Project, Activities.
- Select the activity to which you want to assign a note.
- Display Activity Details, then click the Notebook tab.
To display the Notebook tab, click the Layout Options bar and choose Bottom Layout Options. In the Available Tabs section, select Notebook, click
, then click OK. - Click Add.
- Select the notebook you want to assign. To assign multiple notebooks, hold down the Ctrl key, then click each notebook you want to assign.
- Click the Assign button, then click the Close button.
- Click Modify to type a description of the activity notebook in an HTML editor. In the editor, you can format text, insert pictures and tables, copy and paste information from other document files (while retaining formatting), and add hyperlinks.
