Remove notebooks from activities
- Choose Project, Activities.
- Select the activity from which you want to remove a note.
- Display Activity Details, then click the Notebook tab.
- Select the notebook you want to remove, then click Delete.
- Click Yes.
Deleting a notebook topic also deletes the topic description associated with the notebook for the selected activity.
