Assign resources to activities
- Choose Project, Activities.
- Select the activity to which you want to assign a resource.
- Display Activity Details, then click the Resources tab.
- Click Add Resource.
- Select the resource you want to assign. If resource security is enabled you can only select resources you have access to.
- Click the Assign button, then click the Close button.
