Assign resources to activities by role
Assigning resources to activities by role facilitates resource staffing for activities because you can use roles with specific skill sets as resource assignments until specific resources can be assigned.
- Choose Project, Activities.
- Select the activity for which you want to assign a resource.
- Display Activity Details, then click the Resources tab.
- Click Assign by Role. The Assign Resources by Role dialog box lists the roles assigned to the selected activities. Under each role is a list of resources who can fulfill the role.
- Select the resource you want to assign. To assign multiple resources, hold down the Ctrl key, then click each resource you want to assign.
Click the Assign button, then click the Close button.
Tip:
When a resource and role share an activity assignment (e.g., when assigning a resource to an activity by role), you can choose to use the rate of the resource or role to calculate costs on the activity.
