Assign roles to activities
- Choose Project, Activities.
- Select the activity to which you want to assign a role.
- Display Activity Details, then click the Resources tab.
- Click Add Role.
- Select the role you want to assign. You can assign multiple roles to an activity. To select more than one item, hold down the Ctrl key, then click each role you want to assign.
- Click Assign, then click Close.
Tip:
If price/unit rates are defined for a role you assign to an activity, you can choose the price/unit rate you want the module to use to calculate cost. Choosing a defined price/unit rate yields more accurate cost planning results. If you do not specify a rate, the module uses the default rate defined in the Project Details, Calculations tab.
