Assign roles to resources from the Resources window
- Choose Enterprise, Resources, then select the resource to which you want to assign a role.
- Click the Roles tab, then click Assign.
- Select the role you want to assign.
- Click the Assign button, then click the Close button.
- In the Roles tab, double-click the Proficiency column and select a skill level.
- If this is the resource's primary role, mark the Primary Role checkbox.
