Assign shared resource calendars to resources
Use this topic to assign a shared resource calendar to a resource. See Create and assign a personal resource calendar to create and assign a personal resource calendar.
- Choose Enterprise, Resources.
- Select the resource to which you want to assign a calendar.
- Click the Details tab, then click
in the Calendar field. To change the calendars display, click the Display Options bar. - Select the calendar you want to assign, then click the Select button.
