Create and assign a personal resource calendar
Use this topic to create and assign a personal resource calendar.
  • When connected to a P6 EPPM database: The following must be done for the user to edit their personal resource calendar: The user must be defined (using P6), a resource representing the user must be defined (using P6 or P6 Professional), and the user must be associated with the corresponding resource (using P6).
  • When connected to a P6 Professional database: The following must be done for the user to edit their personal resource calendar: The user must be defined, a resource representing the user must be defined, and the user must be associated with the corresponding resource.
  1. Choose Enterprise, Resources.
  2. Select the resource to which you want to assign a personal resource calendar. In Resource Details, click the Details tab.
  3. Click Create Personal Calendar.
  4. From the Calendar dialog box, edit the new calendar as discussed in Edit a resource calendar.
  5. Click OK when you finish editing the calendar. The calendar name defaults to <Resource ID> - <Resource Name>.
