Assign Toolbar
Use the Assign toolbar to assign resources, roles, activity code values, predecessors, successors, and activity step templates to the activity you select in the Activities window.
This toolbar is displayed by default, and all of the icons on this toolbar are enabled when the Activities window is active.
The following table provides information about each available icon on the toolbar.
Icon Function Corresponding menu command
"" Opens the Assign Resources dialog box. In this dialog box, you can assign resources, remove existing resource assignments, and replace  resource assignments. Edit > Assign > Resources
"" Opens the Assign Resources by Role dialog box. In this dialog box, you can assign resources based on the selected activity's current role assignments. Edit > Assign > Resources by Role
"" Opens the Assign Roles dialog box. In this dialog box, you can assign roles, remove existing role assignments, and replace role assignments. Edit > Assign > Roles
"" Opens the Assign Activity Codes dialog box. In this dialog box, you can assign activity code values and remove existing activity code value assignments. Edit > Assign > Activity Codes
"" Opens the Assign Predecessors dialog box. In this dialog box, you can assign predecessor activities and remove existing predecessor relationships. Edit > Assign > Predecessors
"" Opens the Assign Successors dialog box. In this dialog box, you can assign successor activities and remove existing successor relationships. Edit > Assign > Successors
"" Opens the Assign Activity Step Templates dialog box, which you can use to assign activity step templates. None
Tip:
  • All of the icons on this toolbar display by default.
  • The icons on this toolbar do not have corresponding shortcut keys.
  • You can right-click on an activity to access a shortcut menu that includes most of the options described in the table.
