Bottom Layout Toolbar
Use the Bottom Layout toolbar to customize the bottom layout of the active window. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
| Icon | Function | Enabled when active window is: | Corresponding menu command |
| Shows or hides window details in the bottom layout. Use window details to view or edit information for the selected item. | All except Tracking | View > Show on Bottom > Details | |
| Shows or hides the Activity Usage Spreadsheet in the bottom layout. | Activities | View > Show on Bottom > Activity Usage Spreadsheet | |
| Shows or hides the Activity Usage Profile in the bottom layout. | Activities | View > Show on Bottom > Activity Usage Profile | |
| Shows or hides the Resource Usage Spreadsheet in the bottom layout. | Activities | View > Show on Bottom > Resource Usage Spreadsheet | |
| Shows or hides the Resource Usage Profile in the bottom layout. | Activities | View > Show on Bottom > Resource Usage Profile | |
| Shows or hides Trace Logic in the bottom layout. | Activities | View > Show on Bottom > Trace Logic | |
| Shows or hides the bottom layout. When you hide the bottom layout, the top layout enlarges to fill the entire work area. | All except Reports | View > Show on Bottom > No Bottom Layout |
Tip:
- All of the icons on this toolbar display by default.
- The icons on this toolbar do not have corresponding shortcut keys.
- To set options for the bottom layout in the Activities, WBS, Projects, and Tracking windows, right-click anywhere in the bottom layout of the active window and choose an available option.
