Change a Gantt Chart bar's label
  1. Display the Gantt Chart, then choose View, Top Layout Options, Bars.
  2. Select the bar.
  3. Click the Bar Labels tab. To add a label to your bar, click Add at the bottom of the Bar Labels tab. To delete a label from your bar, select the label and click Delete at the bottom of the Bar Labels tab. To change the position of a label, select the label, click the Position field, and select a new position. To change a label's display value, select the label, click the Label field, and select a new value.
  4. Click OK. To view your changes without closing this dialog box, click Apply.
