Change a Gantt Chart bar's style
- Display the Gantt Chart, then choose View, Top Layout Options, Bars.
- Select the bar.
- Click the Bar Style tab.
- To change the shape of the bar's Start Endpoint (first field), the height and position of the bar (second field), and the Finish Endpoint (end field), click each corresponding field and select a shape.
- To change the color of the bar's Start Endpoint (first field), body (second field), and the Finish Endpoint (end field), click each corresponding field and select a color.
- To change the pattern of the bar's Start Endpoint (first field), body (second field), and the Finish Endpoint (end field), click each corresponding field and select a pattern.
- To show the bar when you collapse the display to summary level information or to show the bar as a summary bar only, mark the appropriate checkbox.
- Specify the row in which the bar should appear in the Gantt Chart.
- Click OK. To view your changes without closing this dialog box, click Apply.
