Change document status names (P6 Professional Only)
- Choose Admin, Admin Categories.
- Click the Document Status tab.
- Double-click the status whose name you want to change, then type the new name.
Tip:
- To change the order in which document statuses are listed, select the document status you want to move, then click Shift Up or Shift Down.
- If you change the name of a document status, your change applies to all documents with that status assigned.
