Create a document status (P6 Professional Only)
You can create status types that you can assign to documents in any project. A document's status helps you determine which documents are approved work products and documents, standards, and deliverables, and if they can be assigned to activities or work breakdown structure elements.
- Choose Admin, Admin Categories.
- Click the Document Status tab, then click Add.
- Type the name of the new status.
Tip:
To change the order in which document statuses are listed, select the document status you want to move, then click Shift Up or Shift Down.
