Change Predecessors tab columns
- Display Activity Details, then click the Predecessors or Relationships tab.
- Right-click anywhere in the Predecessors tab or the Predecessor area of the Relationships tab, then choose Customize Predecessor Columns.
- To add a column to the Predecessors tab, in the Available Options area, click the column you want to add, then click
. To remove a column from the Predecessors tab, in the Selected Options area, click the column you want to remove, then click
Tip:
- To move all available columns to the Available Options or Selected Options area, click
- To reset the Predecessors tab so that it contains only the default columns, click Default.
- To edit a column's title, width, and alignment, click Edit Column.
