Change Successors tab columns
- Display Activity Details, then click the Successors or Relationships tab.
- Right-click anywhere in the Successors tab or the Successor area of the Relationships tab, then choose Customize Successor Columns.
- To add a column to the Successors tab, in the Available Options column, click the column you want to add, then click
- To remove a column from the Successors tab, in the Selected Options column, click the column you want to remove, then click
Tip:
- To move all available columns to the Available Options or Selected Options area, click
- To reset the Successors tab so that it contains only the default columns, click Default.
- To edit a column's title, width, and alignment, select column and click Edit Column.
