Change Resources tab columns
  1. Choose Project, Activities.
  2. Display Activity Details, then click the Resources tab. See Display window details.
  3. Right-click anywhere in the tab, then choose Customize Resource Columns. To add a column to the Resources tab, in the Available Options section, click the column you want to add, then click
    .To remove a column from the Resources tab, in the Selected Options section, click the column you want to remove, then click
    . To return to the default columns settings, click Default. To change the title, width, and alignment of a column, select column and click Edit Column. To apply your changes without closing this dialog box, click Apply.
  4. Click OK.
