Specify the unit of measure for material resources
A unit of measure describes the quantity of a particular resource. Labor resources are often measured in units of time, such as hours or days; materials can be measured in cubic or linear feet, or perhaps in tons or kilos; items used one-by-one can be measured individually (EA) or as shipped: a box, a case, a pallet. Money is generally measured in monetary units, such as dollars, euros, or yen.
- Choose Enterprise, Resources.
- In the Details tab, choose Material as the resource type for the selected resource.
- Select a value in the Units of Measure field.
- When connected to a P6 EPPM database: You can define a unit of measure for material resources using P6.
- When connected to a P6 Professional database: You can define a unit of measure for material resources in the Units of Measure tab of Admin Categories, in the Admin menu.
- If a unit of measure is not assigned, the unit of measure for the material resource will be Unit.
