Change the display order of menus
You can change the left-to-right display order of menus in the Menu bar.
- Choose View, Toolbars, Customize. Opening the Customize dialog box switches the menus into Edit mode, which enables you to move menus. You do not need to use the Customize dialog to move menus; however, you must leave the dialog open to enable you to move menus.
- Click the menu label you want to move, then drag it left or right. You can place the menu at the beginning or end of the Menu bar, or in between any two menus.
Tip:
You can revert to the default settings for all toolbars and menus.
