Customizing menus
The module provides customizable toolbars that enable you to quickly access all available windows, dialog boxes, and associated functionality. You can:
  • Change the display order of menus
  • Move menu commands
  • Delete menus and menu commands
  • Customize a menu command
  • Create a custom menu
Tip:
The state of your toolbars and menus are saved each time you close the module. To undo all changes to toolbars and menus, you can reset toolbars and menus.
