Change the OBS chart display
- Choose Enterprise, OBS, then click the Display Options bar and choose Chart Font and Colors.
- To change the appearance of the display's text, click Font, then select a new font.
- To change the display's background color, click Back Color, then select a new color.
- To change the display's OBS box color, click Box Color, then select a new color.
Tip:
To change the displayed information, click the Display Options bar, choose Chart Box Template, then select Customize.
